Reducing strain on the electrical system
FuzzAZ
I drive a 2013 lancer, and it is under a very strict warranty. I want to put in a pretty big system over the next year or so, and I was wondering what the best way to reduce strain on my electrical system would be.
My alternator puts out 130A
The first install will pull 500W RMS, 1000 peak.
And the second install will pull an additional 600-700W RMS, 1400 peak.
I can't upgrade my alternator because Mitsubishi doesn't make HO alternators, and it would void my warranty to use a non-Mitsubishi part in it.
I was thinking a big battery, a second battery, a capacitor, and the big 3, but I don't knowhow much it will reduce the strain as much as delay it.
If I put a large battery in the front, and my current one that I'm replacing in the back and isolate them would it help? I'm a delivery driver, so the system is going to be on for roughly 5 hours at a time.
Please look around on the Impala forums and see if they cracked the voltage control. My 13 Silverado was really simple and only required a quick t...
17
1) That is correct. I bought mine from Amazon. Those were the actual links I used to purchase it. If you're budget conscious I'm sure you could...
I have a 2006 Mustang GT and the alternator amperage is 135. I'm running 3 amps totalling 1600 amps, driving 2 subs, 4 - 6x8 and 2 - 6.5. Ive...
FuzzAZ
FuzzAZ
Gilbert, AZ
tc300
    May 18, 2024
    May 18, 2024
