Recommended Crossover for Dyn Esotar2
SillyHoney
Hello everyone.
I am a totally brand new member. I am very glad I found this community.
I have a quick question about crossover:
My system:
Fully active 3-way Dynaudio Esotar 2
DSP: Audison Bitone
Tweeters: Esotar2 110 on A pillar
Midranges: Esotar2 430 on A pillar
Woofers: Esotar2 650 on door (close to kick panel)
Subwoofer: Single Esotar2 1200 in the trunk
The 110 - 430 - 650 are powered by DLS TA2 amp (3 of them in total)
The 1200 is powered by Crown BPX 1100.1
Can anyone recommend me the crossover settings that you believe that would be appropriate for my system?
Thank you!!!
Some safe settings would be 80 Hz 24 dB on the 1200, 80 Hz 24 dB and 1 kHz 24 dB for the 650s, 1 kHz 24 dB and 3 kHz 24 dB for the 430s, and 3 kHz 24 dB for the 110s. Do you have an RTA setup to use to check the frequency response? Even a smartphone RTA app is better than nothing.
Thank you trumpet. Your reply is greatly appreciated.
My professional did the tuning for me and set the following crossover:
E110: 3000Hz 18dB
E430: 250Hz - 3000Hz 18dB
E650: 45Hz - 300Hz 18dB
E1200: 45Hz 24dB
How do you guys think? It's weird? It depends? It's brilliant?
Recommended frequency range 2000–30000 Hz for tweet
Recommended frequency range 200–7000 Hz for midrange
Recommended frequency range 50–4000 Hz for mid bass
Recommended frequency range 18–300 Hz for sub
thats from the pdf i saw...
id try
4000 for the tweet
500 to 4000 m.r.
50 to 500 m.b.
overlap the sub and 70 and down on it.
Nooo, do not low pass the subwoofer that low. That's putting it to waste when it only plays 1 octave and some change. Raise it up and raise the HPF on the mids the same amount, no overlap.
I tried multiple combinations and the best result so far is
4kHz
1kHz - 4kHz
45Hz - 1kHz
45Hz
Slope at 24dB for all.
And it sounds much better now... Thank you guys!
SillyHoney
SillyHoney
Vietnam
SillyHoney
