Really weird thing with one speaker/radio
dantheman170
Tenn
I have a weird little problem. Every time I play this one certain cd, my left front speaker stops playing after a while. If i pop in another cd, it starts working again. Sometimes I have to take out the car radio and wiggle the wire harness by the radio and it'll work again, for a bit. Anyone have any idea what the hell is going on? I had the radio professionally installed and did the speaker myself. Connections are good. It's only when I play this one cd.
the fastest way to fix is not to play that song
if you feel you can;t live without hearing this song
check all wires for loose connect
make sure that the speaker fading in and out is not shorting itself out
I took it to another professional and he said it was fine and so were the connections. It did it again to another cd tho. Im guessing its a loose connection in the back of the actual radio itself. All I have to do is keep fiddling with the **** wire harness in the back of the radio to make that one speaker come back on. The radio was in my old car when i wrecked (granted i was only going 25mph) so yeah im thinking radio got messed up a bit.
Thanks tho 350z, i'll check to see if the speaker is shorting out.
dantheman170
dantheman170
Tenn
dantheman170
michigan born
    May 14, 2026
michigan born
    May 14, 2026
