Rd Audio S.h.w. ?
Then they've done about as much research on the product as you.
To all in this thread, usually you all know I don't get into tit for tat threads like this but the overwhelming amount of bias and stupidity was rampant enough to chap my ***. I apologize for the rest of the people including myself whom have posted in this thread that has strayed from what the content of this thread should of contained.
the truth is, buy some subs....see if you like em...if you dont move on and try a new toy. Tis how it goes with car audio, or any audio for that matter.
indeed. i agree x20
what you should do is tell us what car, space constraints etc.. you have so we can help you achive your goals..
chances are your 1 competing 2 trying to show off.. if thats the case low tunes do much better in manny cases...
question...how many of you guys have tested,played with,heard a shw or a 99z?
I HAVE, I HAVE!!!! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Get two D1 HeavyWeights and buy my RD 7500.1 and be done with it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif :)
As for the DD nuthuggers.... wait until the neo SHW comes out //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
From my experience with 99Z's awesome motor, coil needs to be beefier. Where RD takes the cake //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm not a fan of either company, but last time I checked, Mr. Dante was throwing 40kw to a single Z...how much as someone sent to a shw before? The most I have heard of is 30kw.
op keep the Autotek MM4000's. great amps. my friend sleepy is running 2 of them on 2 18's AQ hdc with the alum coils. sounds great.
Alot of DD and RD nuthuggers here. they both ****
If money isnt an issue then why not go with something bigger than 2 18s??
I call BS on this one for sure.
This is the reason why we were suggesting something insanely expensive (DDz), because money was no issue to the op
Read the above post.
Op, we cant decide for you, you cant go wrong either way. If you have plans on running 4k per sub, I would run the shw over the hw. You cant go wrong with a larger coil.. good luck
look at my ava. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
nativeboy
PIMPING JOKER
nativeboy
Flagstaff, AZ
RE_XXX
michigan born
    May 14, 2026
michigan born
    May 14, 2026
