Rca splitter
  • 5
Ya one more RCA post
I have 3 mono amps (L and R channels) 30' away from the head unit. Long truck. Lol
Should I use y adapters near head unit, with 3 sets of rca's to amp area, have a weaker signal sent over 30' of low resistance
or
From head unit 1 set rca's to amp mounting area then split 3 ways into mono amps, strong signal, higher resistance, less shielding
Is it better to split at beginning of signal or near end of signal
I'm I over thinking things
split it at the amp -- not for any improvement in signal -- just to save the hassle of running 3 long cables.
There's very little signal loss using y-cables -- a few percent maybe.
If you use the crossover in the head unit, then you aren't sending that part of the signal to the amp. (Whether or not that allows a more narrow...
988
This option is better because you need 3 pairs of RCA cables. Tweeters, midrange, and bass. You then use a Y at the amps on the Bass run, then use...
No make or model number on it? Do you have an exact picture of the rear and all its glory?
831
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
842
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
718
Jduane
Jduane
Weymouth, ma
The Camry
