Rca Plugs Where To Ground
Dude you should have both a negative and positive terminal on the amp, I don't think you ever ground the RCA wires, well I've never heard of such an application. And you can add to it if you do it carefuly and don't cross them, though I would sudgest not to for long term conditions because that can introduce new problems such as corrosion and loss of sound quality over time.
well im not sure what booleg is talking about...but it sounds like you have some higher quality rca cables that have the ground on them to try to help w/ any alt. noise....but they also have the ability to become an antenna for gound noise...if your not having a problem w/ the noise from the alt...then dont worry bout it...but if you are....jus ground them to anything that you can ground them to....but make sure its a good ground spot....good luck
No make or model number on it? Do you have an exact picture of the rear and all its glory?
864
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
894
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
755
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
847
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
942
wickedmooch
wickedmooch
South Lyon, MI
MikeofTulsa
