Quick Sub Wiring Question
Don't solder or splice. Strip away 3/4 of an inch off the wires you want to fit at the push terminals. Split each end into a "Y" and cut off half the threads, making the wire half as thick. Then twist the wires together you want, and it should fit. Heat shrinking them together would be a nice touch.
Lowering the thickness of the wire for a fraction of an inch won't effect it's ability to handle wattage. Solder does reduce the conductivity of the wire to terminal connection. Bare copper is better.
Thanks for that fantastic suggestion DidU. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif!!!!
Thanks a lot though seriously, I really needed the help. Will do that then.
x2o
Fuzzy Blue Lights
x2o
Miami, FL
x2o
