Questions on Ported Boxes.
  • 2
more_spl
only have 1, but it's 12"
2,487
Winnipeg
please whoever can help with as much info and questions answered that would be much appreciated.
1) in ported for 2 subs, should you have them in their own chambers with a port per chamber? cuz u should in sealed, but why don't people do that for ported, they use one big chamber. doesn't this give you a "push pull effect" ?
2) would 3 Ft^3 be good for 2 10" MTX T600 subs?
3) when tuning, does it matter how many drivers you have? i was looking to tune @40 hz.. i can just use the tuning calculators and just go from there right, like there's no other tricks or factors involved?
4) my amp doesn't have a subsonic filter, but it only puts out ~450 watts... will i hurt my subs? becuz i heard you only REALLY need a S.S.Filter if you pushing over 600W.. true?
my main concern is w/ my first questions, as i wanna do this right and the best way. thanks
TTT... please guys, i need help before i start making designs //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i know you guys know these answers
Originally posted by more_spl please whoever can help with as much info and questions answered that would be much appreciated.
1) You can make separate chambers, but the problem is the cubic feet and port size have to be EXACTLY the same for each chamber, it's easier to make one big box.
2) Recommended cuft is 1-2 per sub, so 3 should be fine.
3) You have to factor out the displacement each sub takes out
4) Whoever told you that is lying....you need a SS filter if you listen to music or plan to listen to music that hits frequencies below what your box is tuned to......if the sub plays these frequencies the port will lose control of the sub and bad things will happen.
And 40 is a rather higher tuning for your setup....you should considering something in the low 30s
thanks... but don't S.S.Filters start @ 20hZ ? but if people tune their box to like 35hZ, then there's the 15hZ range in between, how do people compensate for that?
Originally posted by more_spl thanks... but don't S.S.Filters start @ 20hZ ? but if people tune their box to like 35hZ, then there's the 15hZ range in between, how do people compensate for that?
You would set the filter to 35 or a little higher.
If you're serious about an 18 in the trunk front firing/trunkwalled go ahead. At least you got electrical covered /w/ a 600rms sub I'd wager. If...
16
3K
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
348
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Thanks for the reply bass addict. I am sure with ya'lls help I'll get it tuned up. Audiobaun has been a huge help. He basically linked everything...
50
5K
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
8
989
more_spl
more_spl
Winnipeg
Gauntlet
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
