I have a 2008 Saturn Aura and I would like to install a new subwoofer.
I am getting an Alpine SWR-12D4
Alpine SWR-12D4 (swr12d4) 12" Dual 4 Ohm Type-R Series Car Subwoofer
I see it on Amazon for much cheaper, but it doesn’t give much specs, so I just want to make sure it is the same thing.
http://www.amazon.com/Alpine-SWR-12D4-Type-R-Subwoofer-4-ohm/dp/B007XW2WTK/
In the description, the RMS Power Handling says 300-1000 watts, but in the Specs tab, it says 600 watt RMS, so I assume that it’s 600 RMS.
The most confusing thing so far is finding the right amp.
I have tried to research how much power and what ohms to use but nothing was clear to me.
I want to get a Class D Monoblock amp.
For the sub I am getting, from what I understand, I want an amp around 600 watts.
I don’t understand which ohms to look at though. Since my sub is DVC, do I get an amp with 600 watts @ 4 ohms or 600 watts @ 2 ohms?
I plan on getting a ported box. The minimum to maximum ported box volume says 1.0 to 2.0 cubic feet, but I heard that those numbers were low, so I was thinking about getting something around 2 cubic feet.
Sonic Electronix doesn’t have a great selection of enclosures, but this is probably the best one I could find.
Belva 1SV12B Single 12" Vented MDF Enclosure - Sonic Electronix
I’m not sure if it is any good, but if anyone knows a better box for the sub I want, please suggest some. I want to stay around the same price, and I don’t want to get a custom one made because it would cost much more.
I found this one on Amazon and I think it might be better and it actually says the fequency it is tuned at.
Amazon.com: R/T 300 Enclosure Series -318-12 Alpine - Single 12-Inch Slot Vented Sub Bass Hatchback Speaker Box with Labyrinth Power Port for Alpine Subs: Car Electronics
For the head unit I think the JVC KD-R530 would be good.
JVC KD-R530 (KDR530) w/ Front USB, iPod Control & Pandora Support
In the picture it looks like there is a wiring harness so I was wondering if it comes with one.
What’s the best place I can get an installation kit so my head unit will fit in my car because the stock one is much larger, along with a wiring harness and an antenna adapter?
I’m not sure what kind of wiring or wiring kit to get either. Would 8 gauge work, or is it pretty much required to get 4 gauge?
Also, how long do all of my wires need to be?
I haven’t done this before but comparing it to my friend’s truck and installation which was fairly easy, it seems like it might be quite difficult for my car. Do you think it is even possible for a beginner to set it up or should I take it in somewhere and have them install it?
