Questions about setting the gain w/multimeter.
de8212
I know setting them with a multimeter isn't the best way but I'm just looking for a starting point.
Here are my components and specs
Pioneer 4200nex head unit
Pioneer 9605 amp.
4 ohms: 75 watts x 4 chan. + 350 watts x 1 chan.
2 ohms: 100 watts x 4 chan. + 600 watts x 1 chan.
Morel Maximo Components up front (running off of front channels of 9605)
90 watts RMS
Morel Maximo Coaxials (rear channels of 9605)
80 watts RMS
Pioneer sub TS-SWX3002.
400 watts nominal
Gonna follow this guide unless someone knows a better method. Link
I'm guessing my front and rears are running at 4 ohms? My fronts have the crossover that came with the morels BTW.
So, if it's 4 ohms I would set the front channels at 17.3V.
Rears would be 17.3V
Sub channel would be 18.7V
Does that look right?
Would it matter that the front channels are driving 6.5's and tweeters?
And I have a Frequency Generator app I downloaded. Would that be ok to use? I see where it says to change HZ but nothing about 0dB level????
I do have a bass control knob that goes in between the head unit and the amp for the sub. Do I set it at Min/Max or somewhere in between.
When I am finished I assume I leave the crossover in the headunit at whatever the default is or do I need to adjust it as well?
Sorry for all the questions. Thanks.
I hope to have time sat or sun to do this so any tips or info is greatly appreciated.
Thanks
Tuning a system seems to be a lost art anymore. Multimeter on your highs?.. test tones?
Set your sub to your music and blend the system together... easy peasy
Loud/clean/clip... its knowing your equipment.
I've used both methods with the exception of o-scope, which is the best method, but the mentioned above works too. I used a 40Hz tone to set my sub gain, then used a small speaker and a song that I'm familiar with. Only thing about using a speaker for gain setting is you need a good ear and a song you know by heart w/o any distortion and sounds like shit.
You set the gain in accordinance with the rms of the speakers and sub.
de8212
de8212
georgia
nauc
