question about RMS power
Hands down going from sealed to a well designed ported should give you the output you're looking for. Even on the same power you'll likely gain noticeably.
If you have the extra space to give it's a no brainer, but get one FOR you. Configured for your vehicle and music tastes to really maximize it's potential
If you're determined to stay with a sealed enclosure, which does have advantages over ported, then the 13w7 will perform somewhat better in both SPL & distortion. OTOH, if you're chasing SPL/SQL, then consider a ported enclosure, which should net you at least 3db+ real world output.
I have a 13w7 at 1,000 w and I feel like a 12 w7 at 1000 watts would sound much better considering the 13w7 needs 1500 watts the get to its full potential. thoughts? I'm just really not impressed with the 13 I got to admit.
Porting would be the next step up. This w7 have a flat BL curve, which means low distortion, in turn, that can make your sub lack the presence you're used to from a subwoofer.
rd 1500 so 1000 watts at 3 ohms.
Again, go ported if space allows for immediate gains. Maximize the gains by getting a custom design or have a knowledgeable builder involved. Its going to be more involved than buying a ported box off the internet. Getting your enclosure done or designed (I love diy) is totally worth it as the thing will be oriented towards your personal goals. Bass takes space and comparing sealed to ported is about as comparable as the physical size... here's an example.
Totally worth it to have it done right. Extension into the low 20s with that JL 40hz signature punch. On top of low delay and hi output. Its a great sub but too many just nuthug the sealed enclosures as most "esoteric" drivers have always been traditionally sealed to achieve sq results but most will feel a lack of output and try to throw power at that JL coil which is notoriously prone to failure when clipped.
My .02
pberrios
pberrios
Boston
shredder1
    Jun 20, 2026
    Jun 20, 2026
