Protecting door speakers
I recently removed my MB Quarts from my doors. 96 Ranger
They were in there for 4 years with nothing at all
protecting them from the weather.
They had no signs of weather damage at all.
I imagine it would depend on how well your door
seals keep out any weather that could harm your speaker.
It's probably different from car to car.
Most of the time I don't. But if I'm suspect of the vehicle. I use foam baffles made by a company called xtc. I get them from partsexpress. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yuh, that's what I've been using - the foam cups. But they require the hole to be a bit bigger and when I put my comp's in they're gonna be in the way. I as thinkin of leaving them out, but I don't want to damage the speakers with rain & snow.
Shaun, how well do your doors seal around the windows? The weatherstripping on mine is like 18 yrs old and not perfect. But water would likely run down the window and miss the speakers. I dunno if I sould make an effort to fit the cups in there or not...
Originally posted by maylar Shaun, how well do your doors seal around the windows? The weatherstripping on mine is like 18 yrs old and not perfect. But water would likely run down the window and miss the speakers. I dunno if I sould make an effort to fit the cups in there or not...
It seals pretty good. I tested it by spraying water in all the cracks
around my windows, then I removed the door panel and looked
inside the door to see if any of the water got in. It was bone dry.
Try testing your window seals for leaks. If everything stays dry
inside, don't worry about protecting the speakers.
maylar
Electrical Weenie
maylar
Connecticut
ShaunMac
michigan born
    May 14, 2026
michigan born
    May 14, 2026
