need some advice on wiring...
mm_55
i have a A4125HCQ audiobahn amp, with 2 AW1051T 10" subs. the subs run 300 RMS each, not sure about the max. (small subs for a big amp, i know) anyways i was wondering if i should run this at 2 ohms or 4 ohms? i'm pretty sure the amp is 250 watts x 2 @ 4 ohms, 500 x 2 @ 2 ohms. if i run 250 watts through 300 RMS subs, is that about right or can i put alot more power into them?
First off, max ratings are insignificant in car audio, so pay no attention to em:)
Secondly, what is the impedance of the subs, are they SVC, DVC, 2,4 ohms?
I'd run them at 4 ohms if possible. You can never hurt a driver by underpowering it, as long as it's not seeing square waves.
dual 4 ohms, 2 ohms, and 8 ohms...so how much should i push through them, and how should i wire them up? parallel or series?
they are 2 ohm and 8 ohm operation. it says dual 4 ohm voice coil... whats that about? if i have them at 8 ohms, run the wires parallel, would it then be 4 ohms? as you can tell i'm new to this...
mm_55
mm_55
Missouri
jay spec
michigan born
    May 14, 2026
michigan born
    May 14, 2026
