Proper way to run head unit and GPS off the same accessory wire???
wmflyfisher
I'm in the process of hooking up my Pioneer double din and hard wiring my GPS. The wiring harness on my 08 Silverado requires me to run a dedicated accessory wire for my head unit. I found a switched (unused) spade under the column that I plan to run this wire to.
I'm also hard wiring my GPS and it will require a 12V (cigarette) outlet somewhere under the dash. Can I run the hot wire from the cig outlet and the head unit together to the same switched spade? If so, do I need to add a relay or anything??
When I hardwired my gps I bought a 10a "Add-a-fuse". If you're not familiar it's a plug that piggybacks off a fuse location in the fuse box. It's good if your running multiple accesories and if you want a dedicated fuse for the "extra's".
P.s. Just make sure you don't just chop the wire off and wire it in directly. Gotta tap into the + and - at the the cig jack plug for the gps. I made that mistake in my younger days and fried a radar detector.
wmflyfisher
wmflyfisher
Athens, GA
Sleeklsc
