you should have clay between the midbass and mdf ring.i dunno if it was asked already (too many posts to read) buton the first page, you out the clay on the ring. i assume u dont mount the midbass on the side where the clay is right?
And clay between the mdf ring and the door //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif .you should have clay between the midbass and mdf ring.
Huh? Work for what?So...would the small dimpled stuff work? I cannot find anything else anywhere.
Uhh sorry, read a page back, i was wondering if the small many bump foam egg carton will work just as good as the big fewer bump stuff.Huh? Work for what?
Ohh...ya, forgot about that, haha, it's been a long day...i've use wood glue to connect two mdf rings before let them sit a day and it should be good to go..
You put wood glue between the 2 mdf rings...wood glue?
And also, since i live in Houston, which is always hot as hell/humid, would clay be a good idea? Also, do i stick clay bwt the 2 mdf rings?
Weather insulation tape may seal around the speaker up, but I do not think that it will stop any resonating.my dad refuses to use clay on the doors (its my car so wtf) but he says its stupid. Instead he says i should use weather insulation tape. So, how does that work out?
Sound deaden your trunk? That may cut down on some vibrations you get up there. Other than that there's not a whole lot you can do. Just use your side mirrors, that's what I do, because my rearview mirror fell off from bass and I can't get the ****er to stay back on.Also, i got my 12w6v2 and i was wondering if theres anything i can put to keep the rearview center mirror from shaking so much.
