project brewing in my head, challenging, but seem like a good way to try new concepts
  • 2
PV Audio
The Vision of Sound
20,912
Indy
hey all, heres where i stand. i just got this idea while enameling my current worklog towers (pics by tomorrow night) and this is what i'm thinking. what i want to do is make a three-way design. i want two mids and a ribbon. the low end will come from a single 10" subwoofer side firing at the base of the speaker. now here's the problem. would I need to use an active xover with this? the reason why i ask is because it seems that i would need to power hhe subwoofer SEPARATE from the actual components. this way, when the current is introduced into the circuit, the mids and tweet get the power that they are allotted to, whereas if I were to just run a passive and have the power run to the sub as well, it wouldn't be as productive. so here's what i'm asking. how would I go about either doing a active/passive xover, or..building a powered subwoofer inside of the cabinet. that last part makes it sound simple, but there will be no visible amps, as the cones will be grilled. i need any helpful suggestions, and deletion of irrelevant posts is appreciated. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
dave
ima post this on diyaudio.com as well, but bump anyway //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You don't need an active setup to make it work. You can do all passive
crossover and have it work. But it's better to drive the subwoofer active
because the crossover parts may cost alot depending on the scenario and
you can't tweak the subwoofer for best sound. Use the plate amps for the
subwoofer and install these in the cabinet in the rear, they have active crossovers
and some may have EQ's and/or other neat features. Check PE plate amps, Adire,
etc.
If you want to expand on the project and do a 4 way, that would be pretty
sweet. Your mains would be 3 way, tweeter, pure midrange, woofer. The subwoofer would be a seperate unit all by itself with built in plate amp or whatever.
This way you can move the sub around the room for best sound, the sub
always stays with you even if you change your mind and want new mains later.
Make a sonotube sub //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif they are simple.
If you want to go mad, active crossover everywhere.
i already have plenty of sub for myself, this is to replace my advents hooked up to the xbox //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
the guys over on diyaudio said to do a 2.5 way..after they explained to me exactly what that is, it seems kinda different than what i was thinking. what i want to do is to have just a speaker (definitive is profess at this) that has a powered sub that receives the signal from the amp by means of one or two binding posts. how do u suggest i do that?
so u mean to send one signal, and just split it with an adapter? could u plz like draw this out lol, i'm slow when it comes to visualizing things unless i write it out
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
743
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
8K
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
Yes. It's one of those fundamental truths I somehow manage to unlearn every time I figure it out. :rolleyes:
I ran 2 10’s aero ported in my 06 mustang years ago. Each box was 1.2 and the subs were diamonds (can’t remember exact model). Best thing to do is...
10
PV Audio
The Vision of Sound
PV Audio
Indy
PV Audio
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
