Canaan
Beatin' the block down
This IS a series tuned 6th order. You are just looking at it wrong.I did. it says hybrid6ht order. 6th order characteristics, blah blah blah. I see nothing about your enclosure that would give "characteristics of a 6th order BP. Looks like a ported enclosure to me.
They flared baffles are just throwing you off. If they where parallel it would make more since. Like this:
As a matter of fact, alot of people look at blow-thru setups wrong. They put the subs in what they think is just a ported box, but when they build the blow-thru it creates a second ported chamber in front of the ported box. They to not take this into account and pretty much just end up guessing at the final outcome for response.
Oh, and gumbi...
Those #'s I originally gave you are likely going to be a little off. I plotted the box with a full open front, not with the restrictions of that trim panel you built. With that, the forward chamber is going to be tuned a little lower. Shouldn't really make much difference though, its was already plotted as a VERY high tuned chamber and you still have a large front "port".
