problem with my amp or HU
bernardo
guys i recently try to bridge my Alpine PDX-4.100
so instead of having 4x100, now i have 2x200.
so i adjust the gain to have 100 RMS per channel, but without distorsion.
i bridged as i read in crutchfield:
http://www.crutchfield.com/App/Produ...115&tab=review
So I put the positives on the odd numbered channels 1 and 3 with their respective negatives on the even numbered channels 2 and 4.
sounds a lot better, but there is a little wierd noise, when i turn on the HU, its like interference, or like the old computer fax-modems.
if I turn the volume up to 15 the noise goes away and the music starts, after that i can listen the HU at any volume level, the noise only appears, when i just turn the HU on.
I already check:
the IC on the HU
the ground on the AMP
try with different GAINS
the speakers conections
the RCA (each one)
what else can it be?
i thought the same, but I change the battery yesterday, since i have the OEM one and now i have the optima yellow one.
the problem continues the same
the noise is just when i turn on the HU, until i move the volume up, then the noise dissapear, and the music begins
the RCAs and speaker wire is runing on the other side as the power wires
bernardo
bernardo
Mexico City
bernardo
BP1Fanatic
BP1Fanatic
