Cheesemind;4114162]Ok, basically I'm a total newb to car audio. I was given a system by a friend for a pretty good deal, I think anyways (Audiobahn 2300HCT amp, and 2 Audiobahn 1206T 12" for 400$ total). You are definitly are a noob and did not research audio enough to know NOT to buy audiobling.
Well, I had it installed, and it sounds great, but it's dimming my lights like crazy and has started to cause electrical problems. Since I payed a local shop (best one in town supposedly) to install it, here are a few problems I've run across in my 2000 Grand Prix: If it was the best shop in town and they carry audiobahn, then you should move.
1) Headlights permanently stay on if the car is on for some reason. Before the sensor would only turn the headlights on at night, and would keep them off in the daytime. Since the install, they stay on permanently. GM vehicles are known to have issues over time with the light sensor on the dash. Installers could have pulled out the sensor or cut the wires possibly but I am betting the sensor is just toast.
2) If I play the music loud enough to where it dims my lights at all, when I step out of the car, it will shock me every time, whereas it never did that before. As stated before, most likley static discharge which is the #1 cause of cars blowing up as the gas pump. Your vehicle is DC not AC so with the car off, it is not possible that the car is shocking you.
3) My ignition key has a chip in it, and for some reason I can't get my key out of the car at random times (this never happened til the system). Here lately I've been playing the stereo at very low volume and I haven't had a problem getting the key out, but if I turn it up for any short length of time, my key will start glitching out again. A car will not hold a key inside it's ignition because of a chip. It will get stuck in the ignition if they key is warn out or the tumblers are damaged. Nothing at all to do with an audio install unless your thundering DB's of doom are screwing with the tumblers which is most likley a 1 in a million.
I've asked the shop if they would do the "big 3" for me and they gave me a wierd look like they never heard of doing such a thing, and assured me that all I would need is a 2nd battery hooked up into the trunk (which I don't have yet because they ran out of the special wire used for that??) ANY shop when installing any amp junk or not that can draw that kind of current should have at LEAST ran 1/0 gauge and upgraded your ground cable from the battery. Just standard practice.
Has anyone experienced anything like this before?
I had a 1998 Lincoln Mark 8 that I had this system installed into (by the same install shop) and within 2 months of getting the system installed (it was dimming the lights in it too) several major electrical parts of the car started to malfunction. I don't know if it was from me playing it even though it was dimming my lights, somehow screwing with the electrical system (Mark 8's are almost totally electrical) or if they're doing something wrong on the install. Sounds like your high wattage dreams played havok on your alternator and battery most likley killing the battery and causing issues or damage to the alternator as it was probably going full tilt all the time trying to keep up with a crap battery that had been drained with no reserve left.
Now when my car went to crap after the install, I wondered if it wasn't the stereo that did it, but without knowledge I just assumed the car was just about to go, and junked it and got a new car. But now that I'm encountering the same sort of problems with my new car, I'm really starting to wonder. It is possible your excessive draw on the electrical system is causing some damage over time to other components. Pretty much like purchasing a camp trailer to be towed by a dodge neon and then getting pissed off that the cars powertrane is going to crap.
Any info would be helpful, thanks.
Sorry if I come across blunt or rude but I tell it how it is. I used to have crazy people all the time blaming shops I worked at or the two I owned for the most retarded of things such as "spark plugs went bad, fuel injectors crapping out, mufflers leaking, headlights burning out... **** I am glad I sold my shops *LOL*
