problem with E10K's
Originally posted by stud(k)muffin so can i wire my 2 12"K's which are dual voice coils, so that i get a 2 ohm load to my amp? or will it be a 1 ohm?
r u talkin wiring them together or seprately
cuz seperatly u can get 2 ohms but wiring them together will only get u 1ohm i think
actually, I don't recommend a 9volt. besides, double/triple A would be so much easier and cheaper to find. you only need the power that the 1.5V AA gives out to visibly see if the cones are moving in or out. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Originally posted by paikiah actually, I don't recommend a 9volt. besides, double/triple A would be so much easier and cheaper to find. you only need the power that the 1.5V AA gives out to visibly see if the cones are moving in or out. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
well i was just sayin what that guy told me
i used 9 volt and it didnt hurt my sub
but i will think about using a AA next time
Originally posted by stud(k)muffin my sub box has a divider in it so how can i wire the subs together?
u dont have to hooked them together if u r wiring each sub at 2 ohms goin to 2 different channels
Wiring for single DVC (Dual Voice Coil) Drivers - Single sub set up
K.44 drivers, O.44 Drivers, A.44 Drivers, A.22 Drivers.
Dual 4 ohm - 2 ohm
Dual 2 ohm - 1 ohm
just do each speaker like that
i hope that is what u r wanting
shortman1984
shortman1984
WV
shortman1984
