problem with bearshare...
still not working? check bearshare under setup->options->connection to make sure the ports match... also you might want to try and fill the port number into both sides on the router page... there is a PORT X - _______ fill in the blank... so it's port 6348 - port 6348
then reboot the computer and the router... if that doesn't work there is more you can try but I dunno.. it's hard to troubleshoot via message boards...
i dl'd ares just for the hell of it and it connected...idk wtf is up with bearshare...a buddy of mine can use it just fine...
i ahd a similar problem a while back. one day it just stopped working. i dl'ed limewire and it worked as well as some other program. never got it to work again. then my comp had to be rebooted so i tried dl;ing the pro version, wouldnt even install. ive given up on ebarshare now, which sucks bc i loved it.
also when i would search i would only get a few results on bands taht shouldhave had alot more. other people would get normal results but on my comp get poor ones. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
ok, i got it to work. what i did was go into my program files and COMPLETELY delete bearshare, all icons and everything. then i rebooted my pc, and did a fresh install....thx for the help.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif :rolleyes: I hate when that works after everything that SHOULD be wrong is fixed.... crappy programming FTL
regal8r
I <3 my CRX
regal8r
Lincoln, NE
regal8r
