problem with bearshare...
yes i have a router, i just turned the built in firewall on but bearshare still didnt work even when it was off...
edit: yes, one day it worked and then just stopped //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
it's not the firewall it's the NAT most likely.... you need to logon to your router and forward port 6348 to your computers IP (will be 192.168.X.X) on both TCP and UDP.... just login to the router and look for NAT setup or "Port Forwarding"
double check that first... maybe turning on the firewall cleared the port forwards...
what type of router (with model #) is it?
ok log onto your router, then go to "security", then "port forwarding", then instead of clicking "application-triggered" like you did before (from your screenshot) click on "persistent port forwarding"
now fill out this form with forwarding on that port I listed above (something like 6348) on TCP and UDP (will take 2 entries) and make the IP 192.168.2.1 and use the same port for "private port":
just tried that but still no luck //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
regal8r
I <3 my CRX
regal8r
Lincoln, NE
regal8r
