Problem fusing my grounds
wow full of fail
1st of all "hooked end of my fuse to wrap around the negative battery terminal" it doesnt work like that you have to use wire then a ring terminal to the batt(positive or neg, lol)
3rd of all you have no clue what your doing and should stay away from your car wiring so you dont start it on fire
wow full of fail
1st, it DOES work like that. It's the same as a ring terminal.
Where the fuck did 2nd of all go?
Next, I obviously DO have a clue what I'm doing.... you don't so stfu and gtfo.
You only need one fuse per power loop. And since the positive side is isolated from the chassis of the car, you use the positive side. If the ground side shorts to the body before the fuse then the fuse is useless.
wow full of fail
wow full of fail
lol just leave the guy alone, obviously he knows everything.
let him go catch his car on fire
If the ground shorts to the body, since the body is grounded there is 0 difference in potential thus no current flow and no need for a fuse. Nice try though.
Then why cant you figure it out dumb a$$
If the ground shorts to the body then you have no fuse and power will still flow
then if the positive shorts to ground you'll have roasted marshmallows since you have no fuse on the positive
LMAO! dumba$$ just proved himself wrong.
How is that? you need the fuse when positive touches ground. This is called a dead short and it draws infinite current. Whether the fuse is on the positive or the negative, it will still blow breaking the circuit. You guys are idiots.
The starting ask on diyca.com is $2,500, so no telling what they want in the end, maybe $500k lol. Funny that caraudio.com is no longer valid for...
19
76
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
806
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
636
NutHugger
NutHugger
D4S
keep_hope_alive
    May 12, 2024
Brendon Jenness
    May 11, 2024
