Problem fusing my grounds
How is that? you need the fuse when positive touches ground. This is called a dead short and it draws infinite current. Whether the fuse is on the positive or the negative, it will still blow breaking the circuit. You guys are idiots.
are you gonna fuse your entire frame? putting a fuse on the negative run isnt gonna stop anything. go **** some cawk to get your system installed right
/thread
/thread
Lol you idiot I said the negative BATTERY terminal, which IS fusing the entire frame. You nor anyone else can prove how it wouldn't work. /you posting in this thread because you're incompetant.
Didnt say it wouldnt work, just that it isnt effective to double fuse your power loop.
you fuse the (+) side bc if a live wire loosens and grounds out the fuse pops and a fire isn't started. You must fuse the (+) side for this to work... you may fuse the (-) side as well, but you need the fuse on the (+) side 1st and foremost.
NutHugger
NutHugger
D4S
keep_hope_alive
