Premier TS-W5000SPL Setup Help
Heres the spec from Pioneer,ported enclosure,2.0cu.ft with a 4" port which is 8.25" in length.Great for both both and spl!For extreme spl purposes though,u need a box which a total of 19cubes n has a 12"x12" port!!I work at a car audio shop.Sounds Ltd is the name
so my plan is to get this amp: JBL BPX2200.1
This is in my budget also my old amp was the MTX: MTX Audio Thunder1501D.
Subwoofer Mono Amp Specifications JBL.
Amplifier Type: Mono
RMS Power: 2450W x 1 @ 4 Ohms
THD at 4-Ohm RMS Power: 0.5 %
RMS Power: 1810W x 1 @ 1 Ohm
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: None
Frequency Response: 22-302 Hz
Signal to Noise Ratio: 67 dB
Fuse Rating: n/a
let me know thanks.
No need to inform me on the specs of the JBL amps.Im an official JBL dealer,busy building my Golf 4 with a full JBL GTi system!!Go for the JBL amp you wont make a mistake!!That amp can run any 120volt appliance with a 60hz sine wave input!!Its got some mega power!!
use the gz122,i hope the subs fit though!! //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Step-Up Features From the OBCON GZ328-12
Larger Volume, Higher Overall Output
1" MDF Construction
3/4" Lexan Front Window
Interior Lined with V-Blok© Sound Damping
Subwoofer Enclosure Specifications
Enclosure Type: ported
Subwoofer Opening Size: 12"
Number of Subwoofers: 2
Enclosure Material: MDF w/ plexi
Speaker Terminal Type: binding posts
Ported Chamber Volume: 2.20 cu. ft.
External Dimensions: 16" H x 34" W x 19 1/2" D
wil that work Xplod?
come on guys can you guys give me a demension for a box??
The Pioneer is comming in Monday. I will be running 1 Pioneer W5000spl. Looking at a Length of 34" and Height of 14"
thanks much
Step-Up Features From the OBCON GZ328-12 Larger Volume, Higher Overall Output
1" MDF Construction
yeah go for it!!
The W5000spl should be comming in monday //content.invisioncic.com/y282845/emoticons/popcorn.gif.32dd9e22fd77e77bc3c907062768fcd2.gif
It should be fun. //content.invisioncic.com/y282845/emoticons/imdaman.gif.bc6c552e19aa4ad8c47461144f40eb1a.gif
Hello guys,
I am using the MTX Audio Thunder1501D amp and 4guage wires.
I made the box the Subwoofer is not loud what can be wrong..?
MY W7 13.5 was louder and the gain was only 30% up.
To bump this sub I need the gain all the way up 100%..
someone please help //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
DO NOT USE THE GAIN CONTROL AS A SUBWOOFER VOLUME SETTING!
the gain setting tells the amp the amount of voltage your head unit is sending to the amplifier. set it to your h/u's preamp voltage, and leave it alone.
Check out your h/u and see if you might have accidentally turned a setting down, or maybe your h/u's equalizer. Check your wiring, maybe your wired it in series rather than in parallel. Just double check everything.
thanks for the quick reply.
do you guys know how its wired up two ohms on the W5000spl?
also is the amp good enough to push this W5000spl?
thanks
I have one 12 Premier TS-W5000SPL and I want to put it in a 2004 yukon and can some one tell me the sizes to make a ported box and how big to make the box and can i run a mtx 1501d 1500whtts amp to run the pioneer??
thanks.
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
766
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
bossman032
bossman032
killa cali
bossman032
