Premier TS-W5000SPL Setup Help
Heres the spec from Pioneer,ported enclosure,2.0cu.ft with a 4" port which is 8.25" in length.Great for both both and spl!For extreme spl purposes though,u need a box which a total of 19cubes n has a 12"x12" port!!I work at a car audio shop.Sounds Ltd is the name
so my plan is to get this amp: JBL BPX2200.1
This is in my budget also my old amp was the MTX: MTX Audio Thunder1501D.
Subwoofer Mono Amp Specifications JBL.
Amplifier Type: Mono
RMS Power: 2450W x 1 @ 4 Ohms
THD at 4-Ohm RMS Power: 0.5 %
RMS Power: 1810W x 1 @ 1 Ohm
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: None
Frequency Response: 22-302 Hz
Signal to Noise Ratio: 67 dB
Fuse Rating: n/a
let me know thanks.
No need to inform me on the specs of the JBL amps.Im an official JBL dealer,busy building my Golf 4 with a full JBL GTi system!!Go for the JBL amp you wont make a mistake!!That amp can run any 120volt appliance with a 60hz sine wave input!!Its got some mega power!!
use the gz122,i hope the subs fit though!! //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Step-Up Features From the OBCON GZ328-12
Larger Volume, Higher Overall Output
1" MDF Construction
3/4" Lexan Front Window
Interior Lined with V-Blok© Sound Damping
Subwoofer Enclosure Specifications
Enclosure Type: ported
Subwoofer Opening Size: 12"
Number of Subwoofers: 2
Enclosure Material: MDF w/ plexi
Speaker Terminal Type: binding posts
Ported Chamber Volume: 2.20 cu. ft.
External Dimensions: 16" H x 34" W x 19 1/2" D
wil that work Xplod?
come on guys can you guys give me a demension for a box??
The Pioneer is comming in Monday. I will be running 1 Pioneer W5000spl. Looking at a Length of 34" and Height of 14"
thanks much
Step-Up Features From the OBCON GZ328-12 Larger Volume, Higher Overall Output
1" MDF Construction
yeah go for it!!
The W5000spl should be comming in monday //content.invisioncic.com/y282845/emoticons/popcorn.gif.32dd9e22fd77e77bc3c907062768fcd2.gif
It should be fun. //content.invisioncic.com/y282845/emoticons/imdaman.gif.bc6c552e19aa4ad8c47461144f40eb1a.gif
Hello guys,
I am using the MTX Audio Thunder1501D amp and 4guage wires.
I made the box the Subwoofer is not loud what can be wrong..?
MY W7 13.5 was louder and the gain was only 30% up.
To bump this sub I need the gain all the way up 100%..
someone please help //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
DO NOT USE THE GAIN CONTROL AS A SUBWOOFER VOLUME SETTING!
the gain setting tells the amp the amount of voltage your head unit is sending to the amplifier. set it to your h/u's preamp voltage, and leave it alone.
Check out your h/u and see if you might have accidentally turned a setting down, or maybe your h/u's equalizer. Check your wiring, maybe your wired it in series rather than in parallel. Just double check everything.
I have one 12 Premier TS-W5000SPL and I want to put it in a 2004 yukon and can some one tell me the sizes to make a ported box and how big to make the box and can i run a mtx 1501d 1500whtts amp to run the pioneer??
thanks.
bossman032
bossman032
killa cali
bossman032
vegang
vegang
