Premier TS-W5000SPL Setup Help
bossman032
killa cali
Hey guys,
I wanna get two Premier TS-W5000SPL for my civic.
The question is before I had a JLW7 13.5 the box dimensions were
35.5" Length
13" Width (needs at least 2 inches by the sub)
16" tall
this box was a perfect fit for my civic. I was wondering If I get a similar box like this can I put two 12s at the back instead of one in a similar box.
here is the link to my setup before. //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=5720292391&ssPageName=STRK:MEDW:IT
http://pg.photos.yahoo.com/ph/bossman032@sbcglobal.net/detail?.dir=b8c2&.dnm=7783.jpg&.src=ph
http://pg.photos.yahoo.com/ph/bossman032@sbcglobal.net/detail?.dir=b8c2&.dnm=76cd.jpg&.src=ph
excuse me If I sound like an Idiot still learning. //content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif
please if you have to in**** each other please do it via pm. my other thread was ruined. //content.invisioncic.com/y282845/emoticons/blow_up.gif.f2a780e8b12ae09e264cb01720b8dca2.gif
I was going to use it for every day use and spl.
how you like yours Xplod? I saw the pictures they look crazy.
How heavy are they??
also I wanna run two //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
3 cuft sealed
external measure.
H= 18.8 inch
W=29.5 inch
H= 12.2 inch
using 3/4" MDF
1 Top, 1 bottom : 12.2 X 29.5 inch
1 front, 1 back : 17.31 X 28 inch
2 sides, : 17.31 X 12.2 inch
divide equally to match 1.5 cuft per sub.
i got TS-W2000SPL single sub, in a sealed box, its hittin hard but doesnt peak @ higher frequencies, example (make it clap- busta rhymes) it doesnt produce the peaks in that song, so am goin ported,
i sugest you single TS-W5000SPL in ported, better than 2 in sealed.
and wish u good luck
3 cuft sealed external measure.
H= 18.8 inch
W=29.5 inch
H= 12.2 inch
using 3/4" MDF
yea I was thinking getting a ported box not a Sealed. Since I would have two TS-W5000SPL it would be better to have a ported box.
here is how my trunk looks like.
http://pg.photos.yahoo.com/ph/bossman032@sbcglobal.net/album?.dir=8764
link to see a better picture. download it to see better. //content.invisioncic.com/y282845/emoticons/suave.gif.858fc102f7646e678ee8af7e1fbc41d1.gif
These subs weigh in at 31.3 kgs,may not sound like a lot but ****!!My 1st enclosure in my van was a massive 8cubes and it was a slot vent type!!They worked beautifully in there(surprizingly).Im using a 4,5cube ported box now(strictly spl),like the pic shows,with a 12" port which is 12" long.Gettin a good 153db so far with 2000w rms per sub,but they can handle a lot more.These **** things dont even warm up after some serious torture.Pioneer however have launched an vented enclosure for the sub,its on their site.Apparently it works great for both music and spl!I've got 2 on order,just have to wait and see for myself if it works.
Oh and another thing as you can see,I've been playin around with boxes for quite some time now,like a year now,and believe me,if you dont build it right it gonna break!!Jus for fun sake,I took a normal cheapskate chipboard ported box and tried them in there,what a bad idea!The box exploded the 1st time we burped the subs!!
Got a mad scientist freak buddy who designs amps!!Actually anything electronic.Done a design on this amp now which delivers 2000w rms at 2 ohms 14.4v.Im currently running them at 17.8v so I havnt yet checked the rms values on the bench again.He reckons dis thing can run with 22volts input!!Scary stuff man,I aint attemptin it!!I'll take some pics and upload them soon.Oh yes and these amps can be run with a master ans slave config!!1st time we tried it the top of the box broke!!
shoot, well, then send me one amp as u can c , am also in africa //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
hope to see some pics of this amp soon //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Xplod_ur_mind,
what would be a good box for these pionners.
I want to run two of these 5000spl.
Also my trunk length is around 34inch.
Height is about 13inch.
Width about 16inch.
thanks let me know.. ronald
also what are you doing ins South Af? //content.invisioncic.com/y282845/emoticons/driving.gif.c4dead4599dda895032b63e51f52b126.gif
Heres the spec from Pioneer,ported enclosure,2.0cu.ft with a 4" port which is 8.25" in length.Great for both both and spl!For extreme spl purposes though,u need a box which a total of 19cubes n has a 12"x12" port!!I work at a car audio shop.Sounds Ltd is the name
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
769
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
bossman032
bossman032
killa cali
bossman032
