ppi 88r dsp
****, forgot to add..
im getting 6 volts from the wire, but when i conected it to my amps i get 12 volt from it.
that i dont get, but it works.
wait what. so when you measure your remote out at a relay connect 85. you only get 6 volts but you when you connect it directly to the amps. you get 12 volts?
well i dont know. it will not turn on the relay.
i checked the wire at the dsp and it reads 6 volts..
so i said to myself lets see if it will turn the amps on, and it did.
so i checked the remote turn on terminal at the amp and it reads 12 volts..
ya i dont get it.
but it does turn my 4 amps on..
but becoes i dont like the 5 volts out im going to get a delay relay and be done with it.
as ppi just got back with me on fixing it....
$110 just to fix it. not including shipping both ways..
screwww that.
ya i dont get it.
screwww that.
Better to just buy another one lol
i will be down the road..
well if i can ever get the money lol...
but for now its great...
there's only one thing i have not figured out yet..
my system is sound alot better but i cant get it loud..
im sure its something im not doing..
i have the h/u a flat, crossovers off/flat. any boost off.....
i can max the h/u out 62/62 and its just not loud like it was.
now the bass is nasty but not the front stage.
ya i dont get it.
screwww that.
why are they charging you, its a fking factory defect.
Just check your input levels and set them accordingly on the software.
well because i got if from here...
the guy said it was new, and it looked new but i did not buy " new " ..
so no warranty for me...
ya im pissed....
its time for a better dsp...
wew lad,
maybe. but not sure 5 volts will turn a relay on.
never tried it.
but its ok, for now ill get a delay relay and be done with the remote output from it.
well because i got if from here...the guy said it was new, and it looked new but i did not buy " new " ..
ya im pissed....
wew lad,
never tried it.
you can just do a dedicated remote run for the amps seperate from the dsp. If you experience no turn on pops then you should be good.
i would if i could.
i tried it.
the manual says the dsp must turn on before any other think.
thats one of the reasons the remote turn on from dsp has a 2 sec. delay.
when i tried it, the dsp was not controlling the amps.
thats why i need a delay relay. there only $15 and i can set the delay from 2 sec. to 3min.
before the dsp i had a relay on all my amps, so its already wired. ill just replace the regular relay for the delay one.
ok update..
just spent a little time adjusting everything... and wow i love it..
its loud a **** now and clear as can be.
very detailed ..
ill go into it again to fine tune but im very happy now.
i like it.
i can only imagine how good a nice dsp will be.
down the road i want a better one.
one with all 3 sets of inputs.
is there a device you guys recomend to convert a set of rca ( input ) to optic ( output ) ?
should i use the optic or the rca aux input for my tablet ?
does the optic sound better ? never used that connection before.
since when does the dsp need to turn on 2 seconds before any amp? what the hell lol i literally have all 3 of my amps and my dsp wired in parallel with my remote out from my headunit
big scott
blazin low, and loud
big scott
edgewood, md
big scott
    May 16, 2024
    May 16, 2024
