ppi 88r dsp
****, forgot to add..
im getting 6 volts from the wire, but when i conected it to my amps i get 12 volt from it.
that i dont get, but it works.
wait what. so when you measure your remote out at a relay connect 85. you only get 6 volts but you when you connect it directly to the amps. you get 12 volts?
well i dont know. it will not turn on the relay.
i checked the wire at the dsp and it reads 6 volts..
so i said to myself lets see if it will turn the amps on, and it did.
so i checked the remote turn on terminal at the amp and it reads 12 volts..
ya i dont get it.
but it does turn my 4 amps on..
but becoes i dont like the 5 volts out im going to get a delay relay and be done with it.
as ppi just got back with me on fixing it....
$110 just to fix it. not including shipping both ways..
screwww that.
ya i dont get it.
screwww that.
Better to just buy another one lol
i will be down the road..
well if i can ever get the money lol...
but for now its great...
there's only one thing i have not figured out yet..
my system is sound alot better but i cant get it loud..
im sure its something im not doing..
i have the h/u a flat, crossovers off/flat. any boost off.....
i can max the h/u out 62/62 and its just not loud like it was.
now the bass is nasty but not the front stage.
ya i dont get it.
screwww that.
why are they charging you, its a fking factory defect.
Just check your input levels and set them accordingly on the software.
well because i got if from here...
the guy said it was new, and it looked new but i did not buy " new " ..
so no warranty for me...
ya im pissed....
its time for a better dsp...
wew lad,
maybe. but not sure 5 volts will turn a relay on.
never tried it.
but its ok, for now ill get a delay relay and be done with the remote output from it.
well because i got if from here...the guy said it was new, and it looked new but i did not buy " new " ..
ya im pissed....
wew lad,
never tried it.
you can just do a dedicated remote run for the amps seperate from the dsp. If you experience no turn on pops then you should be good.
i would if i could.
i tried it.
the manual says the dsp must turn on before any other think.
thats one of the reasons the remote turn on from dsp has a 2 sec. delay.
when i tried it, the dsp was not controlling the amps.
thats why i need a delay relay. there only $15 and i can set the delay from 2 sec. to 3min.
before the dsp i had a relay on all my amps, so its already wired. ill just replace the regular relay for the delay one.
ok update..
just spent a little time adjusting everything... and wow i love it..
its loud a **** now and clear as can be.
very detailed ..
ill go into it again to fine tune but im very happy now.
i like it.
i can only imagine how good a nice dsp will be.
down the road i want a better one.
one with all 3 sets of inputs.
is there a device you guys recomend to convert a set of rca ( input ) to optic ( output ) ?
should i use the optic or the rca aux input for my tablet ?
does the optic sound better ? never used that connection before.
since when does the dsp need to turn on 2 seconds before any amp? what the hell lol i literally have all 3 of my amps and my dsp wired in parallel with my remote out from my headunit
big scott
blazin low, and loud
big scott
edgewood, md
big scott
vegang
vegang
