Power Wire Choices...
  • Thread starter Noles3
  • Start date
  • Replies 1
  • Views 1K
  • 1
N
Noles3
Guest
Currently I have a RF 400x4 running my mid/highs (Rear: 3-way Kenwood and Front: Kenwood DB+ Excelon 2 ways) and a 250x2 running my sub (12" Kicker VR). Here is my problem. I need to move my power wire and was thinking of replacing it cause it looks like the coating is wearing off (its not a name brand). What should I replace it with? Monster cable, Rockford Fosgate cable? My friend even suggested going to Home Depot and buying the same gauge wire, spending less $$$ and it being a little more sturdy (yet a little less flexible)? But, will it work and is it worth it since its not a "car" power wire? Please any help is greatly appreciated.
Expensive stuff is just cheap wire with a name brand stamped on it. Flexibility is probably the most important issue. Just find some 8 ga with a reasonable strand count (500 or so) and you'll be good. You can get a nice kit off ebay for $20 or so.
The hardware stuff is fine, just harder to work with.
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
Oh, total opposite. i play with storage bins full of wire scraps from past installs for fun. I hoard decent grade wires from audio homies...
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Guest
n2audio
