Power before getting alternative power source?
  • 4
id recommend one good secondary batt to start with but a bigger alt will also help.i personally run 2 120ah batts plus my factory 55ah batt on 2500w with big three and 0gauge all around factory 135amp alt
What specs should I look for if I am just trying to power the 2000w amp? I mean common sense tells me to get something like a Kinetik KHC2000 but if I could get away with a cheaper battery. I know this is not a cheap hobby but there has to be entry level or budget oriented gear with a rep for quality. Thanks again fellas.
well start by finding what amp your factory alt is go online to like autozone or advanced auto
put your car info in and search alternators should tell u the amperage of it I.was running
a kicker 1500.1 and a rockford 400-2 with factory alt.. 0 gauge, big 3 and a kinetik 1400 with
no issues.
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
532
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
393
805
Patthehat033
Patthehat033
Missouri
tdford5
    May 12, 2024
Brendon Jenness
    May 11, 2024
