power antenna connection
If you do not have a power antenna ,then this wire does not have to be connected to any.Just cap it off.Hope this has helped
You should be using an adapter harness that includes the ant wire. If you're wiring directly to the car's electricals then you need to check with a Miata forum to find out what color the ant wire is.
I sure did. Nostalgia is what brought me to this website, wondering if it still existed. I can still name some of the people and describe some of...
192
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
554
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
410
mike98789
mike98789
Silver Spring, MD
mike98789
    May 18, 2024
    May 16, 2024
