Ports
Im putting around 250 RMS to them......It was never a sealed box...I built it ported....any idea how to tune it to get some good spl and keep my sq
What will give me tuning of 34Hz.....I never mentioned a port length....What port length do you use to get around a 34 Hz or anything in that range to make my subs hit harder? Again...I have 3 3" cuts and PVC right now that is 13" long...However I can always shorten them if I have to. THanks
Alright, Thanks alot. I'll just set them to that and keep the 13" ports. I have a subsonic filter that is set at 20 Hz, you think my subs are safe with that?? And last, can you tell me how I figure out how to tune a box, or how I can calculate the tuning of a box. Thanks
Download WinISD Pro...and itll do it for ya...well...pretty much. Youll get the hang of it. You should be okay with that filter, as long as you dont feed the subs a butt load of power more than they want.. You may eventually want to get a higher filter though.. Watch your subs closely and make sure they dont bottom out.
Alright Thanks....The only problem is that program doesnt have the Alpne Type-R's as one of the driver options....you guys know any sub similair to it, or how I can get the Type-r's as a driver?
You can enter its parameters....Use your users manual for the sub...enter the parameters in the add drivers section...You should be good.. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Alright....So final, you think those box dimensions and port diameters and lengths will be a good box. Any idea how much louder I should expect it to be from a small Q-Logic box (Had to get rid of that piece of ****)??
The late 80's early 90's car's OEM speakers were of the same quality as today's offerings. The main difference was the rear speakers were enclosed...
10
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
The black rca out is your mono sub output. That is the one you would use for signal to your sub amp.
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
Miller
Miller
Chicago,IL
crhye250r
