Raul-tsv
Hello,
i am trying to "build" a sealed box for two 12" subwoofers and i am using the winisd software for that, but i am confuse in the volume and qtc parameters...
the specs of each woofers are:
- qts 0.37
- vas 56.3 l
- fs 26.1 hz
- re 4 ohm
- xmax 5 mm
- spl 87db
- pe 1200w
- dia 11 in
- the manufacturer recommends the sealed box and 1 cubic feet of volume
when i use the program with the specs i mentioned before it displays a 1.5 volumen ft^3
for the 2 woofers and a qtc of 0.71, but when i change the volume to reach the recommended qtc between .9 and 1.1 the volumen decrease at less than 1 ft^3 for both woofers, is this correct? cause the manufacturer recommends 1ft^3 for each one
or how can i configure the parameters to build the "perfect box" for this woofers
thanks for your help,
Raul
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif :crazy: //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif :crazy:
- qts 0.37
- vas 56.3 l
- fs 26.1 hz
- re 4 ohm
- xmax 5 mm
- spl 87db
- pe 1200w
- dia 11 in
Raul
