Deamonicus3
PyRaMiD AmPs RuLe!!!!!!
I've got a Q-Logic 1.0 cu ft sub enclosure. It can be used sealed or ported. Well I've had it sealed for a while and I'd like to see the difference porting makes. It has a precut hole that has a plug in it. It also came with a 12" tube to be used for porting. I just can't figure out how long the tube should be. It came with instructions on cutting the tube depeding on what you want the sub tuned to. I can't figure them out. It doesn't define the abreviations well enough. It's only a 10" sub so I know it will not hit real low.
