Port Question...
  • 4
plugitin
She Bangs
6,906
Da U.P. eh?
Ok, im building a wall in my car at the moment. Im trying to figure out how i can get a drivers side port to work. I know drivers side port will meter better usually. My question is, if i port on top, will i lose a lot of output? It would be much easier to port on top instead of the drivers side...
im not sure if you will lose audible output as i've never personally built a wall but have been around alot, you may not meter as well because of the way everything loads, but sometimes you need to do what works for you and not the once a month or once a year meter.
good point...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so you dont have a design you are looking for one?
ok i thought you had a "port on top design" and wanted to tweek it but you need whole design
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Personally I'd likely go slot ported with the low tuned side of the box and aero on the high tuned side. 6th orders are just big by design
Yep. Point A. The last 3/4 of an inch on the exit end of the port won’t count in the displacement though. Take 3/4 off your length. You also have...
830
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
711
plugitin
She Bangs
plugitin
Da U.P. eh?
dappa5
    May 19, 2024
    May 19, 2024
