port help
Originally posted by crakerhead for making a port can you just cut a rectangle?
Cutting a rectangle won't help in any way possible...you have to tune the box to a certain frequency, this is acheived by having ports a certain size/length...Jmac will help ya out...
32x18x20
jbl 1200.1
dd 9515
it's bandpass w/2 6"circle ports that are 8 inches deep. it has two chambers. the ports aren't in the chamber w/the magnet.
I'd have the internal port end 7" away from the back wall and just roundover that corner. That back (rounded) wall should effectively extend the...
None so far, there was a factory 8 inch subwoofer that I took out for a pass through, I'm definitely going to have to get some sound deadening...
10
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
704
crakerhead
crakerhead
Richmond, VA
crakerhead
    May 18, 2024
    May 18, 2024
