Poorly designed 4th order
I'd just tear apart the old box and move the internal wall shrinking the sealed to 4 and making the ported 12 and retune to 47hz if you don't like it build a ported box if you do rebuild it a little nicer reused boxes are usually very ugly.
well i get free sheets of material from work. would 4 total sealed and 8 ported work good? I was thinking adjustable ports so i can test out tuning. will 47 hz still give me good lows into the low 30's and high 20's?
more help less argue please
Dude. You made a box and failed. Buy more wood, try something different. My advice would be to pay a professional for a design, and avoid bandpass if you don't have a lot of time and wood to spare and a really good reason to even bother.
actually no, mine burped 47s almost right out of the gate. Oh yeah, with 1kw as well....
just went down to a shop and got metered and did a 142 on music at 42 hz idk if that is good or not but they said i would get much better results if i did a 2:1
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
930
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
4bannger
4bannger
FLA
4bannger
Brendon Jenness
    May 8, 2024
    May 8, 2024
