PLS help with ohm rating real quick!
again, pardon my newness, but to my understanding, i can wire 2 4-ohm speakers to a 2-ohm overall resistance. So is this correct: I need an amp that puts out 150 x 2 @ 2-ohm?
That amp will be fine for the comp set. Both the mid and tweet when hooked up to the crossover will give you a 4 ohm load to the amp.
you can wire them down to 2 ohms together but it will be mono then.. so i wouldnt suggest it lol
try to get an amp that does slightly over 150 x 2 @ 4 and give yourself a little headroom..
dan7532
dan7532
St. Louis, MO
Etac
