Plexiglass or MDF Box Construction???
  • 2
quiimari
I Am Tiger Woods
Building a box for 2 10"s sealed for about .5 to .8 cu/ft per chamber underneath the backseat of my silverado, I was always going to build the boxes out of MDF high density fiberboard, but then I remembered plexiglass, its not that hard to work with and it would look cooler, what would be the better choice??
This. I have a friend who builds boxes and all he uses is lexan. You could get a big fat 1” thick window in there. OP, Iirc your window is...
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
4
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
9
3K
quiimari
I Am Tiger Woods
quiimari
Tha Bay Area
mgaidica
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
