Please help!!!
Okay but quick question. Could theses subs hold about 50 more rms each.
---------- Post added at 06:58 PM ---------- Previous post was at 06:58 PM ----------
Also how much over rms is too much
They can handle a lot more than that. You'll be fine. 50rms is nothing.
Papermaker is a troll don't listen to him... Soundqube 1200 will do but a 2200 will hammer them!!! Just set gain up for clean power and all good. The 1200watt amp make sure you have big 3 done and a nice AGM battery under the hood.... If you get the 2200 then you should get a HO alternator.. A good alt from excessive amperage will last a life time so it's not like your wasting money because you
Can use it or sell it and get some money back. While battery's will last roughly 5-7years properly maintained so you can't sell them and get you money back like an alternator.. Just alittle food for your brain to think about.
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
TRAVii199
TRAVii199
Abbeville, GA
Papermaker85
    May 31, 2024
    May 24, 2024
