Planet audio big bang 2400.1
joshy629
PLANET AUDIO BIG BANG SERIES 2400.1 3000W MAX amp
2 of the mounting holes on one side are broke off because they are cheap plastic. and the ones on the other side are loose as well due to this cheap plastic.
other than that no scratches good as new
mono channel amp!!
3000W MAX;
1000W X 1 @ 4
1600W X 1 @ 2
2400W X 1 @ 1
SIGNAL-TO-NOISE RATIO: 100 DB
210 shipped
subs for sale in sub class.
never clamped it. it moved the 2 lvl 4 15s really good. so id say its darn close to it. its one of planet audios best amps
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
180
joshy629
joshy629
lawrenceburg ky
jonnyv718
    May 31, 2024
    May 24, 2024
