pioneer pico fuse?
That may be a pita. My rcas are not like that but connect with a plug on the end. Ther are 3 separate but they attach with wired if you understand what I am saying.
So can I put some wire in the rca connection I am using if it does not touch the center prong and then fasten that to the chassis? If not can I solder wire around the rear set and attatch that to the chassis?
Hell that easy enough. Would you do that or solder around the un used one. Putting it in the outer sleeve seems like the fastest as easiest for sure.
Yet another reason I am probably going to stick with alpine. I am getting a pioneer in a few days because of a trade I will install it and probably not like it or get noise and than sell it, and than get my 9887
Mine makes absolutely zero noise again. I would just ground the rca from the beginning and forget about it.
gqjeff
Waz up????
gqjeff
IL
gqjeff
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
