pioneer pico fuse?
gqjeff
Waz up????
963
IL
Do all of them have it. My hu has worked flawless since installing it with no alt whine or AC fan noise. Today I pulled it out to hook up the mic for time alignment and when I did it made a loud scratchy noise. Ever since then only when the car is on I get alt whine and AC fan noise through the speakers. When the car is off it sounds great. P980bt is the hu in question. Thanks
Yes when I pulled the deck out the rca came out. Does it make since I only have the sounds while the has the engine running?
The ac fan also.... I am pissed off. Any idea of turn around time and cost or can you supply a link to the grounding of the Rca's to the chassis?
If all else fails I will go that route. Rather try and fix it instead of masking it if grounding them is easy enough. Thanks for the heads up though.. Last resort or do a lot of guys run ground loop isolators?
I heard it's like $90 and about 2-3 weeks. the pic above is what you need to do but you can also do it in a cleaner fashion.all i did was unscrew my rca a little pinched the wire in it and tightened it back up then hooked it to the chassis.just dont ground the center pin of the rca
oh yeah my deck had a huge problem when going from 0-1 on the volume there was a loud thump and then it wouls make like a sinewave though my woofers like I was burping my van and this fixed it for me
gqjeff
Waz up????
gqjeff
IL
gqjeff
Mike Mccabe
