Pioneer GM-D8604 Amp Dyno
Jeez.... I'm getting old timers... I'll just add that one to my database. Got some time on my hands ATM if you'd like I can try to whip one up to your preferred measurements/dimensions... sorry
My current box is 22w x 14h x 14.5d. Have plenty more room on the w and d. Uses 2 3" ports firing out the side. Tuned around 36hz. I'd rather have a slot port firing back.
Looks like that second box would be 2.03ft3 net at 34.96hz according to winisd... on a 750 watt amp (that's what I used the 1st time) everything looks pretty good to me.
Just a little displacement change...  that's pretty much all I saw as far as the different sub was concerned (using the TS-W3003D4). Again...It looks good.
Think that one would work for your vehicle?
That last one looked nice to me... I'd do it if it was my vehicle.
A lot if debating went into the 1st attempt (other thread... yes... I remember)... that one ought to be about right imo.
Yeah I will probably keep it for now. Had the RF501bd but it took a dump. The GTR-1001 I have now doesn't have a ssf but don't need it for what I play.
Eventually get a D2 of a different brand and run the amp at 4ohm for 700+ watts its all I need.
I was talking about the second design above... if you'd like more output increasing port area/volume ought to do it and that one above models-up well.
It's not going to sound inaccurate Imo... that one ought to be fine above.
Nice and punchy with decent low end.
So on a Side note, I just swapped out my CT 500.2 today which is supposed to be 800 x 2 at 2 ohms. I  put in the pioneer GM 8604 running at 2 ohms bridged aka 1 ohms each channel.  First off, its a lot noisier than the CT, which had very slight noise.   I'll do something to fix this... Now for Performance, it gets just as loud and slightly less SQ in a direct swap, After tuning which required a 1db 2khz and 3.15khz bump (they were negatives before.) in the EQ, they sound pretty much the same as the CT.   Here's the real reason why I swapped. At 1 ohm operation its runs ice cold and is 1/4 the size of the CT 500.2.and drops less voltage. Overall super happy with the swap.
Any issues running this amp at 3 ohms or 2 ohms stereo? I have heard people say that class d type amps aren't as good running loads under 4 ohm stereo compared to an a/b class not sure if those are older amps or the newer ones also?
it depends on the type of amp. I'm running this thing at 2 ohms bridged which is 1 ohms per channel when you factor it out and at best it gets slightly warmer than room temperature. Zero issues so far.
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
336
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
760
bigblank69
bigblank69
Eureka, MO
stephgirl
    May 16, 2024
    May 16, 2024
