Pics of my setup? Suggestions?
Sealed have tight , and cleaner bass response ,Ported can be good at sound quality also if tuned down around 29Hz-32Hz ,but ported is usually for us boom boys that like loud smack my assss and call me sally music.
i gotta ask what speakers were in your sub box? who the hell would put speakers in a sub box? then instead of atleast using wood to block the hole, you use tape //content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif
Probably was something like this:
Piezo horn tweets ftw!
Thanks for the constructive criticism... not... Anyway I put wood blocks in the holes now. I didnt' before because I was in a diff state at the moment and I could not do that. whats a powercap or is that sarcasm.
More Pics? Amp/Grounding Pics:
The Grounding-
Speakers that use to be in the box, I specially connected them =P
Subs and Box after adding on wood panels to block holes -
How I have the sub set while I drive minus the board -
My car itself -
Sweet mother of.....Why is there like 30 extra feet of red wire just coiled there? Also A vacuum is your friend.
NINJA EDIT: If that crimped piece of wire that you layed over your seat joint isn't a fire hazard, then I don't know what is.
You see, I don't really have the money to do that. and its better that I just do it myself so that I learn. Plus its a whole lot cheaper. The Subs + box cost me only 50 dollars. Good condition too for the subs. I am probably going to buy a pair of JL W7 Subs when my KFC's break. why buy new subs when I can just use them now, but I think I could make them pound harder if I make a new box, just not sure how.
Well I'll be honest. The w30003 was one of my 1st subs. And I can't truly say I was ever impressed. Did it fill out the low end? Yes, but if I could go back I would have gone a different way. As for you situation. Either as you mentioned A. build a box to the specs of the subs B. Buy a simple Q-Logic box since they are cheap and as you said you don't quite have the $$ for a new box C. Hit up a pawn/swap shop that builds boxes and test them out there and see if you like the sound.
gotgohan
gotgohan
Illinois
traksta15
