traksta15
I love lamp.
What you should do with THIS system......
1. your amp does this:
RMS Power: 300W x 1 @ 4 ohms
RMS Power: 550W x 1 @ 2 ohms
so you should wire your subs like this:
you'd be over powering them a lil bit i guess, but they should be fine IMO....
2. cut your wire at the NEEDED length, not like the pics show....it looks tons better and gives you extra wire if needed for another project
3. build a new box, you can have that done under $30 if u do it your self, if you can't build it, buy a cheap q-logic at bb or ccc, or even a used 1 off a buddy (just make sure the specs match up)
4. bolt ur amp down, not only does it protect it from gettin stolen, it'll keep it from sliding around and pulling on your wires.....i couldn't tell if it was bolted down, just thought i'd suggest it.
5. can't tell where ur ground is grounded to, it should be grounded to the frame, be sure and scrape the pain off before grounding though.
6. get rid of those tweeters in your headrest...sell them/keep them/set them on fire....heck throwing un needed items at pedestrians is always fun too-lol, jp
.....Just my $.02
.....Just my $.02
