BrianChia
Just because a driver is significantly better on paper doesn't mean that the system will be significantly better. Mismatches in quality levels of the drivers can also result in a worse or at least mismatched sound quality of the overall system. Distortion at certain bands becomes relatively MORE noticeable so the system may sound worse psychologically. Also a better driver will still require a better crossover to fully realize it's potential, not just a textbook alignment. So mixing the RS midrange, the Dayton silkie, and the Pioneer woofer is mixing three drivers that are in different classes altogether and also have different "timbers", whereas the 3 Pioneers probably are in a similar class and are most likely more closely "timber" matched. Without spending considerable time and effort on crossover design or using testing and measuring equipment, the end result of one system is not guaranteed to be better than the end result of the other system even if the drivers used are more expensive and better on paper.
