Photos of new line arrays
holy shit 96 tweets in total how big is that office
Looks like ~6 foot tall line array. 6 foot is good for a room with 8 foot ceiling,
but 7 foot is nicer. Looks like > 8 foot ceiling.
nice, whats the efficiency like on one of those?
Line array sensitivity is a variable that you can control to some degree.
You can make it very high or lame. 16 NSB per tower at 8 ohm wiring is
about 98dB sensitivity. If you choose 2 ohm wiring, 104dB. The tweeters should
be able to accomodate the 98 - 104 range by doing proper wiring.
I have no idea on how he wired up his array.
96 tweeters is just stupid.
What is stupid is making a line array with less tweeters. When it comes to
line array, more is better. That's how you get low distortion and higher SPL,
and large sound stage if you design it as such. Narrow sound stage can be
made by using power tapering.
It's a low cost array, the tweeters used are the bare minimum requirements.
Spend more coin and get better tweeters to refine the sound. But it has potential
if the crossovers and amps are good.
Ehh, I'd rather have less tweeters of a higher quality. At a certain point, your only going to lose so much distortion and gain so much clarity from a lack of mechanical excursion.
I use to think that way before I experimented with line arrays. I use to
think that an array of cheap drivers = cheap sound.
This is only true at a certain higher SPL level when you reach the drivers
performance limit and produce higher distortion. Every cheap driver has potential
to sound good at lower SPL, it's when you turn up the volume that problems start
to manifest audibly. If the driver is a decent design, it will sound pretty good at
lower SPL.
Use headphones as an example. The drivers in headphones are small and low
in SPL, yet they sound amazing when placed next to your ear. They distort like
mad when you crank it. The sound is high end, but SPL lacks.
In a line array, you raise SPL by 'quantity' of drivers {mutual coupling] and/or
electrical gain by how you wire the array.
Lets say that budget array has 48 tweeters per tower. Tweeter distortion is
1/48 lower in an array a the same SPL level as the single tweeter.
Hypothetical;
Lets say those tweeters are 86dB sensitivity and they have good vertical dispersion. 48 of them can boost line array sensitivity up to 103dB by mutual
coupling. Lets say the tweeter is 8 ohms each. If you can wire up the array for
a 1 ohm load, the total sensitivity is 112dB sensitivity.
Apply 1 watt of power to the array to generate 112dB of treble. You have
48 tweeters, each tweeters gets 0.02 watts. Each tweeter hardly does any
work, distortion is low, SPL is high because of the line array 'effect'.
Imagine what happens when you use better tweeters. You can use
less tweeters but it won't be a real line array anymore, it's a hybrid speaker
that tries to look like a line array but ain't. It can sound great but it's not
a line array.
If you have a turd that smells.... By putting a bunch of those turds in a bag they should stop smelling.... RIGHT? NO!!!!
Welcome to the world of "it doesn't make sense" line arrays.....
If you have a turd that smells.... By putting a bunch of those turds in a bag they should stop smelling.... RIGHT? NO!!!!Welcome to the world of "it doesn't make sense" line arrays.....
Do you need some links to study how line arrays work so it starts making sense?
.. because I can't dumb down my posts more than I already do so this topic makes
sense to you... Since day one you never understood or improved your knowledge
on this subject.
thylantyr
thylantyr
[Yoda] Belong to us all your base are...
thadman
