Phers1er's build log...
Phers1er
I'm in the process of rebuilding my system and figured why not post a few pics.
There really has not been a game plan..... I'm kind of making things up as I go and hoping for the best. Any reasonable suggestions would be most appreciated.
my system will be installed in my P.O.S. 02 cavalier and will consist of
1-rockford fosgate 3sixty.2
1- set hertz hsk 165 comps
3- rockford fosgate 25th anniversary punch 150's
and a pair of SSA Icon 15's(awaiting recones at the momment.//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif)
So far I have made some mounting brackets for the hertz mids and my amp rack.
more pics and updates will follow but I don't have alot of time to work on my car
so finishing this will be slow going.
Here is how I made my caveman brackets.
The green marks the angle I want cut from the bracket
here's the comps.
The amp rack was finished before I decided to post this stuff up so the best I can do is show how it is constructed.//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
next: I'll be installing comps.
hopefully some time this week if its not too hot.
Whoah, how did you get that bracket cut at an angle? Good work btw.
Thanks man,
I did that on a band saw by standing it up on end.... and believe it or not I still have all of my fingers.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Thanks man,I did that on a band saw by standing it up on end.... and believe it or not I still have all of my fingers.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
btw: I meant mention that this is my first atempt at a custom install so If you see something that doesn't look right. please let me know! Most of my stuff in the past has just been a no frills/just make it work type of thing.
Started on the doors today...
Passenger side.
knu Konceptz 12 ga. wire
4 lbs. of black non-drying clay
The little nylon spacers are to keep the dust cap from hitting the door panel.(for some reason it sticks out a little further than the mounting flange
I also added some 1/2" foam to the inside of the door panels (sorry no pics).
So far the doors seem pretty solid.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Phers1er
Phers1er
St. louis
mazzasec
Mike Mccabe
